Where to find Rocky parts in Adelaide?
EnFlaMEd
Unread post by EnFlaMEd » January 10th, 2012, 9:46 pm
Hey Guys
I need a few things for my F75 but I am finding impossible to find even a single Rocky in a wrecking yard anywhere. Does anyone know of anywhere that might have some?
danielk
Re: Where to find Rocky parts in Adelaide?
Unread post by danielk » January 11th, 2012, 8:22 pm
What are you chasing?
There are a few Daihatsu wreckers around but most dont have complete cars. They ust strip off whats valuable and sell the rest as scrap metal
EnFlaMEd
Unread post by EnFlaMEd » January 11th, 2012, 10:05 pm
Mainly a complete steering column and front left stub axel assembly. Also trying to track down a factory intercooler motor to strip the manifold and cooler etc off.
DR - Doctor
Unread post by DR - Doctor » July 2nd, 2012, 12:41 pm
Try these guy's http://www.exjap.com.au/
EnFlaMEd
Unread post by EnFlaMEd » July 31st, 2012, 11:35 pm
Thanks for the link Doctor Ill check it out.
I managed to find most of the parts I need on a Rocky at U-Pull-It, Gillman. However I am now chasing a fully manual transfer box. The non vacuum operated one. So if anyone has any ideas where I can get one please let me know. Having absolutely no luck finding anything here at the moment. I also need a radiator shroud and a new engine fan!
I am considering swapping the standard radiator setup over to a spare supra one that I have here with a big 16" Thermofan. Anyone had much luck running different radiator setups?
DR - Doctor
Unread post by DR - Doctor » August 1st, 2012, 10:55 am
Hey EnFlaMEd no problems..
If you are desperate for bits & not strapped for $$$ these guys in the UK have some bits for different models in stock.
http://www.milneroffroad.com/daihatsu/fourtrakrocky
Also there are clutch fans on ebay..
http://www.ebay.com.au/sch/i.html?_nkw= ... m270.l1313
EnFlaMEd
Unread post by EnFlaMEd » August 1st, 2012, 6:04 pm
Unfortunately exjap don't have anything however City Dismantlers do have the fan and shroud. However they want $60 for the shroud which is ok but they also want $95 just for the fan, not including the hub!
Also those ebay listings are for the the hub only and not the fan which I need unfortunately. Might just go grab the fan off something else at U-pull-it, I already got a jackaroo fan to bolt up but its too big but no doubt there will be something similar if not the same to the rocky one.
Failing that I think Ill just mod in the supra radiator seeing as I already have it plus some spare thermo fans laying around.
Cheers for the links anyway mate.
danielk
Unread post by danielk » August 17th, 2012, 4:30 pm
Just put a 16" thermo fan on your current radiator
1990 Daihatsu Rocky Sports Afield. 2.8tD. 30" Maxxis Bighorns, lift, snorkel.
Check out my little truck in MY SHED
Return to “Rocky”
