285/75/16's on a frontera
loppa
Unread post by loppa » February 27th, 2009, 6:23 pm
Hey guys going to buy new tyres soon and want 33's, Im looking at buying the silverstone mt 117 sport in the 285 75 16. How do you think they would go (power wise) on my fronty I have a little 2.2l petrol?
chikoroll
Unread post by chikoroll » February 27th, 2009, 8:13 pm
just change the gears in the diff and the rotors to slotted rotors, you'll be fine (braking is a good thing to have also)
which year fronty do you have (might be able to use the jackaroo centres)
loppa
Unread post by loppa » February 27th, 2009, 8:37 pm
chikoroll wrote:just change the gears in the diff and the rotors to slotted rotors, you'll be fine (braking is a good thing to have also)
I have a 1999 model 2door
chikoroll
Unread post by chikoroll » February 27th, 2009, 8:46 pm
modified 12 bolt diff, you can use the jackaroo diff ratios
- quote from the jackaroo section of australia4wd.com
might pay to make a post in the main section, asking how to calculate diff ratios needed for tyre size increases
In the 98 and later models, the 3.5V6 auto is a 4.1:1 diff. The V6 manual and the 3.0 diesel are 4.3:1 diff.
The manual also lists a 4.555:1 and 4.777:1 diffs that were in the older 3.1 diesels and 3.2 petrols.
Gear ratio (to 1)
4.100(6VE1)
4.300(4JX1, 6VE1)
4.555(4JG2–TC, 6VD1)
4.777(4JG2)
MUman
Unread post by MUman » March 3rd, 2009, 10:03 am
Your low down torque would be less, just means more clutch work on the uphill/rock ledges and soft sand, but should be right.
I'm assuming that you have had a suspension and body lifts done ?
:thumb:
[size=75]94 3.1L Turbo Diesel MU, 2.5" suspension lift, 2" body Lift, 33" Bighorns, Front and Rear Autolockers, Rock Sliders, alloy winch bar, roof racks, 240 lightforces, UHF, 120amp alternator, dual batteries, snorkel, 80L waeco fridge and turbo timer [/size]
Corindi
Unread post by Corindi » March 3rd, 2009, 1:40 pm
my son has 33's on his 98 fronty. You can see it going up a hill we call widowmaker before guzzler, a couple of issues back on the mags DVD. They called it a MU, but it is a 2.2 fronty like yours. It still goes fine on the highway, but the gearing is too high for 4wding in the steep country.
www.BillabongFurniture.com.au
loppa
Unread post by loppa » March 3rd, 2009, 7:45 pm
MUman wrote:Your low down torque would be less, just means more clutch work on the uphill/rock ledges and soft sand, but should be right.
:thumb:
Yeah I've had the suspension and a body lift done, I have 265/75/16's on it now just wanted sumthin bigger.
loppa
Unread post by loppa » March 3rd, 2009, 7:47 pm
Well guys i ordered my tyres today I stayed away from the silverstone mtt 117 sports in 285/75/16's and went the maxxis bighorns in a 255/85/16 to try and keep the width down but still have a 33 on it.
chikoroll
Unread post by chikoroll » March 3rd, 2009, 11:06 pm
255/85 should also fit inside your wheel wells on the stock rims
MUman
Unread post by MUman » March 10th, 2009, 11:56 am
chikoroll wrote:255/85 should also fit inside your wheel wells on the stock rims
At least at that width its far less strain on the steering components. Wish I could trade my 33 x 12.5 Bighorns for a set of 33x 10.5 for that same reason.
:thumb:
Return to “Frontera”
