Any ideas on likely Frontera Timing Belt Replacement Costs?
mischef
Unread post by mischef » August 12th, 2012, 7:20 pm
Hi,
Just got my 2000 LWB frontera serviced and was told that it appeared to of never had a timing belt replaced.
It has done almost 230K and I am eager to get it changed.
Does anyone know an approximate cost for doing this?
Mungrel
Re: Any ideas on likely Frontera Timing Belt Replacement Cos
Unread post by Mungrel » August 13th, 2012, 11:28 am
Which engine mate?
SOHC, DOHC
If its the 3.2L 6VD1 SOHC engine, its not too bad, belt was around $100, idler pulley was around the $70, Tensioner pulley was around $120, the water pump was internal so add $150 for that (Cheap insurance).
Not a difficult job on that engine, but time consuming. (as it is on any engine i guess)
I read somewhere the holden manual recommends 3 or 4 hrs to change it, but realistically, allow 5 or 6.
When in doubt,
mischef
Unread post by mischef » August 13th, 2012, 2:44 pm
Thanks for that.
fronty00
Unread post by fronty00 » March 6th, 2013, 11:41 pm
Hey,
If you are not doing it yourself you should budget about $1100 i had mine done about a year ago and when it was time.
We needed the timing belt kit which has new pulleys tensioner and belt this was around $500 then we replaced the cam cover seals and the water pump as that comes off to do it so might was well do it while you are there.
Low range is your friend
Return to “Frontera”
