2001 Jackaroo - A/C belt failed, now no start?! Any Ideas?
Findin- out
Unread post by Findin- out » March 25th, 2014, 4:57 pm
Got my jack early last year and until about 10 weeks ago never a problem... My air con belt snapped so number one son got another and replaced it . All good car starts he takes it for a drive belt to tight and snaps so he turn car of removes what left of belt goes to drive home but car won't start. Got lube mobile out to look at it they say fuel injector so sent it to fuel injector mob 9 weeks later they still don't know why it won't start so was wondering if anyone had any ideas please
Re: 2001jackaroo won't go
Unread post by mydmax » March 25th, 2014, 6:45 pm
What engine is in it?
Can't see how a tight belt is going to snap.
If the belt has gone walkies and it is a V6 then it possibly has damaged the crank sensor and then it won't start.
Shouldn't take 9 weeks to fix. Are they casting a new engine block and machining all the holes to size or something similar?
In 9 weeks anyone could replace every part of the vehicle and that would fix it.
Did you say it is at a fool injector place?
Findin- out
Re: 2001 Jackaroo - A/C belt failed, now no start?! Any Idea
Unread post by Findin- out » March 25th, 2014, 7:00 pm
We got lube mobile out because we at a loss to why it wouldn't start he hooked it up to computer it said nothing wrong he went over everything said fuel injectors it's a diesal so sent it to fuel injector mob, guy there when not avoiding our calls says he stumped not know what wrong with it was getting an auto electrician in last week and is getting back to me
Unread post by mydmax » March 25th, 2014, 7:59 pm
Is it a 4Jx1 engine?
They can have a number of things wrong and all stop it from starting.
Low oil level , low oil pressure, wrong oil viscosity.
I am not familiar with those if it is a 4Jx1
If it is the only thing is to find someone who is familiar with them. Auto elecs won't be, Most fuel injection places won't have a clue. most diesel places won't know either. Maybe an enthusiast at a Holden dealer will.
Try Australia4wd forum, there are blokes there who own and know them.
-CorEY-
Unread post by -CorEY- » August 7th, 2014, 9:10 pm
mate should of clutched it worked for mine
Rd28
Rainwulf
Unread post by Rainwulf » April 29th, 2015, 10:49 am
Check the camshaft position sensor.. its right in the path of a whipping broken AC belt.
Return to “Jackaroo”
