Rodeo Recall
Waters 87
Rodeo Recall
Unread post by Waters 87 » June 14th, 2009, 6:27 pm
Hi, has anyone heard about a recall on the 07 rodeo's. It has something to do with cardon build up on the valve and injectors?
07 RA Rodeo Maxxis Buckshots, TJM Winch Bar, Hella 140 Spotlights, Uniden Uhf, Custom Canopy, Custom Roof Rack with boat rack and ARB Awning , Under Tray Toolbox's, Dual Battery System, Barrett HF
ML01UZ
Unread post by ML01UZ » June 14th, 2009, 7:03 pm
The recall is for 07ra built up to about June 07, some injector retaining bolts were not tightened correctly causing carbon build up, the recall is to inspect for carbon buildup and check the torque of the injector bolts. If it has carbon build up then the engine will be replaced with a new fan to clutch engine.
You should have got a letter if yours is affected by the recall providing you are the original owner or have updated your details with Holden, If you are concerned about it pm me your VIN and I will check it for you.
Waters 87
Unread post by Waters 87 » June 14th, 2009, 9:23 pm
Why i asked is because my bosses son's rodeo sounds like its dropped a valve this morning. He mentioned something about the recall when he dropped it off at the shed.
Waters 87
Unread post by Waters 87 » June 15th, 2009, 6:53 pm
Found out what happnened to the bosses son's rodeo. It looks like the sump has been pushed up all of about 3mm and has kinked the oil pick up line. So the motor has run without surficent oil. What a design fault having the oil pick up line 3mm off the bottom and at the front of the sump?????
ML01UZ
Unread post by ML01UZ » June 15th, 2009, 7:12 pm
it's pretty common to dint the sump, the noise is normally lack of oil at the timing chain, I have seen a lot of sumps straightened out and no engine problems later on.
I would never take one of these off road without a decent bash plate (not the factory piece of tinfoil)
Waters 87
Unread post by Waters 87 » June 15th, 2009, 9:34 pm
The funny thing is that the place where the pick up is there isn't any bash plate at all lol. And all that ute has done is pig hunting around banana and cane farms.
STEELJOCKEY
Unread post by STEELJOCKEY » June 17th, 2009, 2:20 pm
ML01UZ wrote:The recall is for 07ra built up to about June 07, some injector retaining bolts were not tightened correctly causing carbon build up, the recall is to inspect for carbon buildup and check the torque of the injector bolts. If it has carbon build up then the engine will be replaced with a new fan to clutch engine.
Sounds like mine, just bought it coupla weeks ago, sent the change of owner details but haven't heard anything about it. Where can I track this down? might explain why I'm not too impressed with fuel economy.
ML01UZ
Unread post by ML01UZ » June 18th, 2009, 6:40 pm
Pm me your vin and I will check it for you.
STEELJOCKEY
Unread post by STEELJOCKEY » June 18th, 2009, 7:30 pm
ML01UZ wrote:Pm me your vin and I will check it for you.
Rang up Holden, she's all ok- no recall for mine
Return to “Rodeo”
