Anyone changed a crank position sensor? Where is it?
themth370
Unread post by themth370 » September 10th, 2016, 5:12 pm
Hi guys and girls, has any one changed a crank position sensor before ? where is it located ?
Michael
Shann Low
Re: Anyone changed a crank position sensor? Where is it?
Unread post by Shann Low » September 12th, 2016, 2:49 pm
Depends on the vehicle.
For a rodeo I honestly don't know.
But no one else has piped up with a response so here we go anyway.
On my F 250 its down the front near the harmonic balancer!.
On MY Lads ML Triton, its on the rear of clutch housing!
You CAN pick up that info for the ECU from a magnet either on the front of the crank, or at the rear (Flywheel) or indeed - even from the cam shaft!.
Normally if you look in those spots you will pick it up.
Not sure what year or engine config you have.
This might help maybe.
http://www.fixya.com/cars/t3851187-cran ... 1999_isuzu
Or not. :lol:
Return to “Rodeo”
