J5
Re: will stock DMax rims with 245/70R16's fit a 94 Rodeo 4WD
Unread post by J5 » February 19th, 2014, 2:08 pm
shouldnt have any real issues
its pretty much a standard size of tyre , correct offset
bedlam
Unread post by bedlam » February 19th, 2014, 2:10 pm
cool, thanks for your reply
Unread post by mydmax » February 19th, 2014, 4:01 pm
The only thing which may be different is the Dmax rims are 7" and earlier one may be 6.5", not sure, never checked earlier ones but just looking at them they may be slightly narrower.
bedlam
Unread post by bedlam » February 20th, 2014, 10:06 am
thanks mydmax. the rims and tyres are off a brand new DMax, done less than 100 k's
benji-mc
hey all tf rodeo wheel question for newbie
Unread post by benji-mc » February 24th, 2014, 1:57 pm
Hi, i have brought a 1999 Holden Rodeo LT dual cab to get ready for camping/fishing trips with and want to fit a larger tyre on it i am after some peoples experiences with fitting a 15x8 sunraysia rim on with a -23 offset and some 31"x10.5" tyres? I know they would stick out past guard a little bit but nothing a flexi rubber flare wont fix. Rodeo came with 16x7 on it and after doing some research on web it is a little confusing as some say it will hit calliper and others have had no probs, i am only new to this 4WD thing as its my first purchase of such a vehicle and cant wait to mod it any suggestions and help much appreciated.
I live in Northern NSW Glen Innes so a lot of tracks to explore around my way and cant wait.
Oh it has no lift kit of any kind
Regards, Ben
MasterInnovator
Unread post by MasterInnovator » February 24th, 2014, 6:03 pm
i am pretty sure you will be right with a 15" rim a that offset, but i may be wrong
What tyre size?
Unread post by BigDutchy » June 17th, 2014, 9:41 pm
What tyre size would you go for or what do you have...
245 70 16 = 29.5" Are currently on my "new" 1999 TD Rodeo. I would not mind going a little bigger. I have room enough to fit bigger but I am not sure what size to pick.
245 75 16 = 30.5,
265 75 16 =31.6" or
265 70 16 = 30.6"
GBC
Re: What tyre size?
Unread post by GBC » June 18th, 2014, 5:52 am
I had both 245 75 and 265 70 on the Colorado. More offroad bias I'd go the 245 with the bigger sidewall. More on road I'd go with the bit more stable 265. Good balanced size choices, any bigger and the drivetrain will start to struggle. If you want muds I think you'll be stuck with 245 75 if I remember correctly.
RODEODAVE
Re: What tyre size?
Unread post by RODEODAVE » June 18th, 2014, 5:31 pm
I'M RUNNING 265/75/16 on my ra with a bit of rubbing on full lock on the pas side
MasterInnovator
Re: What tyre size?
Unread post by MasterInnovator » June 18th, 2014, 6:29 pm
I am quite happy with my 265/75r 16, they seem to be quite good size as you get the longer footprint=better traction and running pressures that I like on road, the extra sidewall really helps to cushions alot of the bumps
y b normal
Location: just behind the steering wheel,above the pedals & seat., QLD
Re: What tyre size?
Unread post by y b normal » June 19th, 2014, 7:44 pm
I run 235 85 16, on my TF. very happy for on road, off road 265 75 16.
get in, sit down, shut up....& hang on....
simplify... declutter... and go forth with purpose.
Re: What tyre size?
Unread post by BigDutchy » June 19th, 2014, 7:52 pm
Are 235's close to or just over 31" ? I know 265 75's are close to 31.5" in the old money....How does your car go with the bigger tyres?
Is your car a diesel?
Re: What tyre size?
Unread post by mydmax » June 19th, 2014, 8:31 pm
Big Dutchy
Tyre calculator says 31.7" for 235/85/16 and 265/75/16 are about 0.1" smaller dia or 31.6" if it's any help with a decision.
Sambarhunter
Re: What tyre size?
Unread post by Sambarhunter » June 19th, 2014, 9:17 pm
I have a 2001 TD running 245/75/16 Cooper st maxx, and have 2" Suspension lift only. I wouldn't go bigger personally, feels just slightly stallish for general 2WD on road driving as it is.
cotts
Re: What tyre size?
Unread post by cotts » June 20th, 2014, 5:24 pm
03 ra, im running 31/10.5r15 better handling better economy went for the 15's for the sidewall height as a lot of driving was in sandy country and dirt roads, made for a better ride
I to am considering going up to 265/75r16
does anyone have economy figures on this size with 03-05 RA diesel?
Or experience towing with this profile?
Return to “Rodeo”
