supachargd
Unread post by supachargd » June 10th, 2011, 9:08 pm
i have an r9 and it has 33x10.5x15. it only has a bj flip and 2'' bodyblocks without touching the t-bars. rim offset is the same as a std cruiser. has a little bit of rub when turning
DAN54B
Unread post by DAN54B » June 11th, 2011, 4:48 pm
10MRC wrote:i got 35s but have fitted 40s for ******* and giggles...
i have gu diffs front and rear though :)
the best your going to get is 2 inch sus and 2 inch body with 32s
or 4-5inch susp and 1 inch body for 33s
any pics of this???????????????
AusDeo
Unread post by AusDeo » June 13th, 2011, 10:18 am
Clintn & Ducky got it correct.
285 75 16 (33") MT MTZ's on my 03 RA Rodeo.
2.5" Suspension
40mm body
Standard rims
Remove front mudflaps
V6 diffs front and back
Manual hubs to not over stress CV's
Results no broken CV's, slight rubbing on full lock on sway bar other lock on shazy rail, speedo and gearing correct.
05courierv6
Unread post by 05courierv6 » July 21st, 2011, 12:43 pm
There bridgestone dueler mt's and the measuring tape say's 32 3/4. There fitted on 16x7 sunnys. Not sure of the off set but its the same thats usually fitted to current model hilux and triton
gilestim
Unread post by gilestim » July 25th, 2011, 4:24 pm
95 tf duel cab
2.5" suspension, 2" bodylift = 285/75 16 mtz's (33's) on 16 x 8 patrol offset rims,
Still scrub a little on suspension compression while turning,
Patrol offset is -28 i think from memory.
Clint N
Unread post by Clint N » July 27th, 2011, 8:05 pm
any1 running 33's on a ra with different rims to std, and do they scrub more/less same ?
olly92
Unread post by olly92 » August 4th, 2011, 9:44 pm
i have just bought a set of 265/70R15's on a set of 15/7 sunnies for my tf rodeo, im running stock suspension and tyres are rubbing on some bumps and sometimes when turning, will a 40mm body lift fix this? im only an apprentice and dont really wanna spend big bucks on a suspension lift so im trying to find the cheapest way.
Dunch88
Unread post by Dunch88 » August 10th, 2011, 11:01 am
hi i have a 97 rodeo 2.8turbo diesel, just wondering what the biggest tyres i can fit without no lift....i have 15/7 rims
squiddy93
Unread post by squiddy93 » November 4th, 2012, 9:23 pm
G'day everyone,
I am new to the world of 4x4 and have just bought a 97 rodeo 2.8L td, stock as a rock and i want to put new wheels and tyres on it as the tyres could do with replacing, was looking at all terrains or some kind of mud/ sand tyres and after looking around online i cant find anything to helpful, was just wondering if anyone had any advice on what
i could get and where to get them. any advice would be muchly appreciated.
cheers,
Breno
mitch~
Unread post by mitch~ » November 9th, 2012, 7:29 pm
Hi Breno,
Not trying to be a douche or anything, but i can see its your first post, and as you are new and keen to 4x4ing you'll probably be here a bit more often. If you check out the "Search Forums" at the top of the thread listing thingo, just type basically anything in there and no doubt it has been covered before, saves threads getting filled up with random questions/stories/photos, you name it people will write it.
Just typing in TYRE CHOICES or similar will no doubt bring up probably 100 threads on peoples experiences with tyres, whether to go a full knobby mud tyre, versus a more suited AT tyre, wheel size offset blah blah, its almost endless.
Best bet to pick up a copy of 4WD Action with a big tyre comparo, ring around some tyre/4x4 shops and ask, or check out the "Rodeo Pics" section - if you see any nice wheel/tyre combos, emulate them!
Have fun, lots of reading a learning!
scoobys rodeo
15" rims on. Ra diesel
Unread post by scoobys rodeo » June 11th, 2013, 8:41 pm
Hi guys just wondering if anyone has fitted 15" rims to there ra, have a snow trip coming up and need to drop down to 245/75's to fit the chains, and can get my hands on a set on 15's for the weekend,
But can they fit?
cotts
Re: 15" rims on. Ra diesel
Unread post by cotts » June 11th, 2013, 9:57 pm
gday scoobys rodeo,
yes mate 15" rims fit fine, i have a set on my RA, no problems with them
RODEODAVE
Unread post by RODEODAVE » June 12th, 2013, 8:53 pm
Running 265/75/16 cooper st on standard alloys with 40mm body lift 2" Sus lift and bj flip very little scrubbing only on full lock with a bit of down hill body roll on pass side
sherm
Unread post by sherm » June 15th, 2013, 1:36 am
Ducky103 wrote:If you fit 33" tyres on a RA rodeo fit V6 auto diffs to bring gearing back to standard.
Hey mate iv'e got 265/75/16's on my ra7 manual t/d rodeo and is more sluggish now do you think this would help my situation and do ya know the ratio's of the auto diffs
Ducky103
Unread post by Ducky103 » June 15th, 2013, 7:37 pm
When the common rail motor was introduced the for the ra7 the diff ratios were also changed.
RA v6 manuals and all diesel models were 4.3:1.
RA v6 automatics were 4.77:1.
Not to sure what ratio RA7 is.
Return to “Rodeo”
