View topic - Thermo Fan Wiring
Thermo Fan Wiring
• Page 1 of 1
Thermo Fan Wiring
Hi guys I am wiring up a thermo fan, I have attached the wiring diagram that came with it but what i want to do is have a switch where I can have it run off the thermo switch but also if i need to manually override it so it comes on straight away. I have shown the switch in the diagram, does anyone knwo where i wire the switch into? thanks.
I have the wire going into 86 hooked onto the power connection of my 3 position switch.
Position 1 is hooked onto the thermal switch.
Position 3 is hooked onto a continous power supply
Position 2 is an 'OFF' position.
When the switch is up, everything runs of the thermal switch.
When the switch is in the middle, the fan is off (i.e. for water crossings)
When the switch is down the fans are continously on
Transport Engineering and Trucking Services
Archerfield Brisbane
Call Simon on 0407 628 191, say Clown Boy sent you
He will look after your rig, trailer or fleet.
waz65 wrote:Why would you want to manually overide the automatic system? to much margin for overheating the engine,the thermal switch should be adjustable
I have an over ride on mine to switch it of if I dunk it in a creek or something
http://www.4wdmonthly.com.au/shed/index.php?content=all&chunk=arbu&user=588
There is no substitute for cubic inches
superg wrote:Because in the event of the thermo switch failing i want backup to be able to run the fan on command rather than be stranded with no cooling, better to have a few more wires than be stuck somewhere having to wire it up then.
Sorry mate , I understand where your coming from now, I ran davis craig thermos in my street and drag cars for years , never had any problems but saying that i never dunked any in water:)
2000 GU TD42T - dual batteries and more to come
RUM IS GOOD , LETS HAVE ANOTHER
Sorry mate, was off for a couple of days.
?Yes that is correct. Except for my always on position I wired a direct power supply (not off ignition).
Personal preference. I figured if I come close to overheating I can turn the engine off, leave the fans on and restart car in 10 minutes to recycle around the cooler water.
Probably not much of a difference though.
• Page 1 of 1
Who is online
