trouble bleeding GQ clutch
Felux
Unread post by Felux » April 20th, 2011, 11:32 am
i just replaced the clutch slave cyl and the clutch hose.
now i'm cant get her to bleed through, it goes rock hard, then because it's power assisted wen i start the car it goes very soft and i cant put it into gear.
any tricks? ideas? anything?
nethergate
Re: trouble bleeding GQ clutch
Unread post by nethergate » April 20th, 2011, 11:58 am
I didnt do it on the gq, but i just did it on the rodeo. when there was a heap of air in the lines i couldnt get it to flow, so i had to undo the nipple, depress the clutch, do the nipple up, pull the clutch up, and repeat about 5 times and then it started to flow on its own. i ended up just gravity bleeding it and it worked really well.
Unread post by Peter Aawen » April 20th, 2011, 1:24 pm
They are hard to bleed! But there is already a lot of stuff posted on the Forum about bleeding Patrol Clutches; it's worth a search and a read, or even just scrolling thru the Nissan Patrol tech index pages & selecting the appropriate threads!
Felux
Unread post by Felux » April 20th, 2011, 5:05 pm
all sorted,
who the **** thought it would be a good idea to put a second bleeder and a totally redundant line for the clutch!
asshole thing!
Return to “General Tech”
