Aussie Brutes | HPI | Hot4s | Street Fords | Street Commodores | Caravan and Motorhome | Magstore
Australian 4WD Action Online Forums - the 4WD, 4x4 and offroad truck community. Get the latest tips, news, reviews, images and video clips.
Go Back   Australian 4WD Action Online Forums - the 4WD, 4x4 and offroad truck community. Get the latest tips, news, reviews, images and video clips. > Model Specific Tech > Nissan > GU Patrol
Reply
LinkBack Thread Tools Display Modes
Old 16-04-2009   #1 (permalink)
patrol4500
Member
patrol4500's Avatar
Default Has anyone fitted a winch to a standard alloy bullbar?
Hey All,
I have a 99 GU wagon and was looking at getting a new ARB winchbar for it. The thing is i really don't need a steel bar as the alloy one should provide enough protection for what i want at the moment, and after looking at prices i almost shat myself. My question is has anyone modified, or Know of anyone that has modified a factory alloy bar to take a winch?
I spoke to the blokes from TJM down here ages ago and i think he said it could be done but wasn't an easy job. My only other option apart from buying a new one is to look out for a second hand one, but they are few and far between in Tassie, and to get one freighted over here probably wouldn't be real cheap either. Any thoughts or experiences in this at all would be appreciated.
Here is a pic of the bar on my Patrol.
Cheers, Dan.
__________________
4.5l GU Patrol 35"cooper STT's, 3.5 inch susp lift, safari snorkel, GME UHF, Dual Fuel, pacemaker extractors, aftermarket recovery points.
Check out my Build Thread
http://www.4wdmonthly.com.au/forum/f...-fitted-34759/
patrol4500 is offline
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post!
Old 16-04-2009   #2 (permalink)
Spider Truck
Junior Member
Spider Truck's Avatar
Send a message via MSN to Spider Truck
Default
Mate, Nissan used to do a factory winch cradle for the standard alloy bar. You just need to cut out the middle slat in the lower grill looking bit, and it sits in the cradle behind it. As the cradle mounted between the chassis rails, and housed the winch, and also backed up to the std bar for the fairlead, the bar did not have to support any weight.
Tigerz11 also doa universal winch cradle that you could have modified to suit the std bar. You will just have to cut a section out for the cable and fair lead.
OR...............
You could go to a manufacturing place and have them make up a cradle for you. Their not too hard to do. Look on the tigerz web site and you will see what they look like.
Good luck, let us know how you go.
Cheers.
__________________
4.5L GU, 2.5" Lift, Narva's, Bocar Bar, Uniden UHF, 33" BFG At's.
Spider Truck, Spider Truck, does wotever a spider truck does.
Can it climb, over rocks, yes it can, its got diff locks,
Look out, here comes the Spider Truck Truck Truck.
Spider Truck is offline
Old 16-04-2009   #3 (permalink)
patrol4500
Member
patrol4500's Avatar
Default
Thanks for that spidertruck, that is very helpful i wasn't aware that there was a cradle you could get for this bar, however i thought something along those lines would be needed to mount a winch in there, i will look into it and see if i can source one or have one made. Will let you know how i go with it.
Cheers, Dan.
__________________
Old 17-04-2009   #4 (permalink)
Casnat
Junior Member
Default
I made a cradle myself. Not too hard.
10mm steel plate for the base. 6mm angle (welded back to back) for sides and 6mm plate for front to mount fairlead. High tensile bolts all round. Uses existing bolt holes.
The hardest part is drilling all the holes through the 10mm plate! Killed a few drill bits!
Photos follow (over a few posts)
Trev
Click image for larger version
ID:	26874   Click image for larger version
ID:	26875   Click image for larger version
ID:	26876   Click image for larger version
ID:	26877   Click image for larger version
Casnat is offline
Old 17-04-2009   #5 (permalink)
Casnat
Junior Member
Default
2nd lot of photos
ID:	26879   Click image for larger version
ID:	26880   Click image for larger version
ID:	26881   Click image for larger version
ID:	26882   Click image for larger version
Casnat is offline
Old 17-04-2009   #6 (permalink)
Casnat
Junior Member
Default
lucky last
ID:	26884   Click image for larger version
Casnat is offline
Old 17-04-2009   #7 (permalink)
Spider Truck
Junior Member
Default
If you find a ood metal shop, they can put the holes in for you.
Plasma cutters are great toys. hehehe
__________________
Old 18-04-2009   #8 (permalink)
patrol4500
Member
patrol4500's Avatar
Default
Nice work Casnat, that looks really neat mate, and doesn't look too hard to make either. Thanks for your input mate, much appreciated the pics explained it well too.
Cheers Dan.
__________________
Old 18-04-2009   #9 (permalink)
patrol4500
Member
patrol4500's Avatar
Default
Yep they are a great toy those plasma cutters, Just so happens today after many many months of looking i may have found a second hand steel winch bar for a decent price here in tassie. I am going for a look at it tomorrow, and if it's any good i will grab it. I am told it's a Nissan bar, but should be a darn site easier to fit a winch to than modifying my alloy one, I will let you guys know how it turns out.
Cheers, Dan.
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Spacer
Powered by vBulletin® Version 3.8.2
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.0.0 (Unregistered)
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118
