49,582
4WD Action   4WD Action
Go Back   Australian 4WD Action Online Forums - the 4WD, 4x4 and offroad truck community. Get the latest tips, news, reviews, images and video clips. > Model Specific Tech > Nissan > Navara
Reply
LinkBack Thread Tools Display Modes
Old 03-03-2009   #1 (permalink)
nasty203
Junior Member
nasty203's Avatar
Default 3.0Ltr d22 EGR Block
Hi Guys just wondering if anyone knows the procedure for blocking the EGR on a D22. I have the info for the 30Ltr Patrol Just wondering if the adjustment on the VNT scew is the same on the D22 given the fact that a 1/4 turn can be the difference between two much boost & not enough
Click image for larger version
nasty203 is offline
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post!
Old 03-03-2009   #2 (permalink)
OffRoadDave
Senior Member
OffRoadDave's Avatar
Shed Profile
Default
Don't worry about the turbo adjustment, there is nothing to adjust on the Navara, they don't run the variable vane turbo. The D22 just runs a standard boost pressure actuated waste gate which means no adjustment necessary.
OffRoadDave is online now
Old 04-03-2009   #3 (permalink)
nasty203
Junior Member
nasty203's Avatar
Default
Thanks for that Shonky that makes the job that much easier.
nasty203 is offline
Old 28-03-2009   #4 (permalink)
mud4b
Member
Send a message via ICQ to mud4b Send a message via MSN to mud4b
Default
Do you have a link to the site for the job?
cheers mark.
__________________
Mud4b/suziworx. Not just suzuki's, all 4wd's. Cheap rates, Not cheap work. I include pics for your build up if wanted... Sms 0439609525.. Sunshine coast, Eudlo, 4554.
mud4b is offline
Old 28-03-2009   #5 (permalink)
tommy222220_0
Member
tommy222220_0's Avatar
Send a message via MSN to tommy222220_0
Default
egr/butterfly mod - The Navara Forum
very benefical (and illegal) on the NAV
exhaust gasses + oil make a mess of your intake :O
Installing a catch can (preferably baffled) is a no brainier after seeing ^^^
__________________
'05 D22 Navara STR
tommy222220_0 is offline
Old 29-03-2009   #6 (permalink)
AndrewD
Junior Member
AndrewD's Avatar
Default
Excuse my ignorance but what is the EGR and what benefits do you get from blocking it. How do you do it?
AndrewD is offline
Old 30-03-2009   #7 (permalink)
tommy222220_0
Member
Default
Quote:
Exhaust Gas Recirculation - basically regulates the amount of exhaust gas allowed back into the intake.
When exhaust gases are mixed with oil (from the positive crankcase ventitation [pcv]) it makes a black sludge which clogs your intake and valves. This is a contributing factor to the problematic ZD30 in early GU patrols, but due to the navara's using a MAP sensor (not MAF like patrols) they haven't has the same overfueling issues.
Benefits:
1. No black sludge in inlet/valves (main reason). Also fit a catch can between PCV and air intake to further help intake.
2. Slight increase in partial throttle response.
3. Slight increase in fuel economy
Blocking is quite easy. Just block pipe where exhaust gasses exit from exhuast mainfold in EGR system and where the entre in the inlet manifold.
There are also some vacuum lines to modify to get the full advantage of this mod.
Please be aware that this is illegal, as it is part of the vehicles pollution reduction system. Modify at your own risk/benefit
__________________
'05 D22 Navara STR
Old 30-03-2009   #8 (permalink)
WILLY6779
Junior Member
Default
So its a worthwhile mod to do then ????
WILLY6779 is offline
Old 31-03-2009   #9 (permalink)
tommy222220_0
Member
Default
Quote:
Yeah, but don't get caught
__________________
'05 D22 Navara STR
Old 03-04-2009   #10 (permalink)
WILLY6779
Junior Member
Smile
I have now blocked the EGR and i do think it makes a difference in low down throttle response. The engine generally sounds a lot smother especially when first started and i have also noticed the puff of black smoke when you nearly stall the motor has pretty well gone now. When i took the pipe of on the inlet to block it i was quite amazed how dirty the pipe was, im bloody sure that by blocking the EGR i have increased the reliablity of the engine because it cant be good for the engine to have all that s$%t being fed back into it.
Old 12-04-2009   #11 (permalink)
Jazdiver
Junior Member
Default
Any pictures on this. What's required to block it off?
Jazdiver is offline
Old 14-06-2010   #12 (permalink)
1TufTruk
Junior Member
Default
there are pics here http://www.navara.asia/general-tech-talk/64-egr-butterfly-mod.html but they not real clear could somone maybe get clearer pics ?
1TufTruk is offline
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin® Version 3.8.2
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.0.0 (Unregistered)
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129
