Aussie Brutes | HPI | Hot4s | Street Fords | Street Commodores | Caravan and Motorhome | Magstore
Australian 4WD Action Online Forums - the 4WD, 4x4 and offroad truck community. Get the latest tips, news, reviews, images and video clips.
Go Back   Australian 4WD Action Online Forums - the 4WD, 4x4 and offroad truck community. Get the latest tips, news, reviews, images and video clips. > Extreme 4WD Magazine > Extreme Chit Chat
Reply
LinkBack Thread Tools Display Modes
Old 28-04-2008   #1 (permalink)
chuck_d
Junior Member
Default internal cage
hey guys i know this prolly has been covered b4
but i need some advice on cages. i have the drawings from CCDA but there is no mention of whether the cages are welded to chassis or bolted
any advice would be great.
thanks guys
__________________
83' MQ Dual Cab RB30 INJ well on its way......
LRP FABRICATIONS ( Bar work, S/Steelsnorkels, Draws, etc) Contact 0417724127 for enquiries.
chuck_d is offline
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post!
Old 28-04-2008   #2 (permalink)
Nasty Nav
Junior Member
Default
It is been my experience that they are bolted. But on the contrary it is something that your not gona take out so why not put some spot welds aswell. Also why not make a latteral bar to go down the sides along the floor. A mate makes his this way. Then there is no chance in a roll over that it will poke through the floor.
__________________
Ride it rough or dont ride it at all!!!!!!!!!!!!!!!!!
www.roughriderracing.com.au
Nasty Nav is offline
Old 28-04-2008   #3 (permalink)
mouse
Junior Member
mouse's Avatar
Default
Cage can be welded or bolted. Plate has to be 15000mm2 with minimum 100mm length per side. (In other words 99mm X 151mm is no good but 100mm X 150mm is fine. Also plate can take up 2 planes (100mm X 100mm plate on floor then 50mm X 100mm plate joined to other plate at 90 degrees.)
Thickness must be more than tube wall thickness. If bolted then minimum of 3 bolts (4 is recommended) to be used M8 grade 8.8. If welded then tube can not be welded directly to the floor it must be welded to the plates described above. CCDA should have all the rules on their site under downloads also CAMS have more detailed rules which is basically the same.
mouse is offline
Old 28-04-2008   #4 (permalink)
chuck_d
Junior Member
Default
cheers lads
so CCDA are nationally recognised regualtions? so if i compete in QLD and its cleared, but if i go down to NSW will it still be fine?
any guys got any pics of their internal cage mounts?, that would be great.
thanks again
__________________
chuck_d is offline
Old 04-05-2008   #5 (permalink)
KrEeCha
Junior Member
Default
hey chuck a few of these ideas may interest you.
wanted - pics of cage to frame tie in - IH8MUD.com Forum
__________________
Thanks friend but I'm not calculating anything. Im just going on the "if I can get it to fit" calculator.
You don't need adaptor plates. That's what gaffer tape was invented for.
KrEeCha is offline
Old 02-06-2008   #6 (permalink)
super jeep
Junior Member
super jeep's Avatar
Default
have a look here at these, ccda uses the cams schedule j for tube and fixings sizes and where and how.CAMS Online Manual of Motor Sport
__________________
if you read this line you've mist the full stop in my post.
super jeep is offline
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Spacer
Powered by vBulletin® Version 3.8.2
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.0.0 (Unregistered)
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118
