49,581
4WD Action   4WD Action
Go Back   Australian 4WD Action Online Forums - the 4WD, 4x4 and offroad truck community. Get the latest tips, news, reviews, images and video clips. > Australian 4WD Action > GPS Tech
Reply
LinkBack Thread Tools Display Modes
Old 15-07-2007   #1 (permalink)
4.2GUst
Senior Member
4.2GUst's Avatar
Default ozi exp and vista
can any one tell me why windows vista wont let me run ozi exp and all i get is a run error??
__________________
FNB 4WD A GREAT AND PROUDLY INDEPENDENT TEAM
4.2GUst is offline
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post!
Old 15-07-2007   #2 (permalink)
fullmetaljacket
Super Moderator
fullmetaljacket's Avatar
Default
may not be vista, mine runs oziexplora perfect.......
__________________
FMJ's BJ40
and old mechanic once told me "If you can cut it you can weld it!", I said "thats good to know cause I just cut one of your spanners in half"
fullmetaljacket is offline
Old 15-07-2007   #3 (permalink)
4.2GUst
Senior Member
4.2GUst's Avatar
Default
used to work fine on xp till i tried to install it on vista !
just tried to install it again and no luck it is exp version 3.95 ?? maybee too old
__________________
4.2GUst is offline
Old 15-07-2007   #4 (permalink)
fullmetaljacket
Super Moderator
Default
may be too old......in vista you can run programs in xp mode, or you could upgrade ozie.....I have the trial/download verson if you want me to email it to you
__________________
FMJ's BJ40
Old 19-07-2007   #5 (permalink)
Jules @ Aawen4x4
Junior Member
Jules @ Aawen4x4's Avatar
Default
Directly From OziExplorer
Running OziExplorer with Windows Vista
Windows Vista has introduced changes to how Windows operates which can cause issues with OziExplorer. The issues below only apply if running the Windows Vista operating system
Vista issues for all OziExplorer3D versions
IMPORTANT You need to download and install version 1.11 of OziExplorer3D. This eliminates a problem where OziExplorer3D freezes when starting up.
If version 1.11 of OziExplorer3D still freezes you may need to install a Vista compatible set of drivers for your graphics card provided by the manufacturer of the graphics card, these are usually provided on the manufacturers web site.
Please note that the manufacturer may not be providing Vista compatible drivers for older graphics cards.
Also see the Vista Data Execution Protection (DEP) issue below.
Vista issues for all OziExplorer versions
Installing OziExplorer
When installing OziExplorer a dialog will appear asking for for permission to install, this is normal for Vista. If you are logged in as Administrator you just need to give permission, if you are not logged in you need to enter an Administrator ID and password before proceeding.
After doing this proceed with the install.
After installing you may receive a warning indicating "This program may not have installed correctly" and you will be presented with 2 options "Reinstall with compatibility settings" and "This program installed correctly". Just choose the "This program installed correctly" option.
Map and Data Folders
If you install OziExplorer into the "Program Files" folder tree then you should not store your maps in the Map folder attached to the OziExplorer folder as Vista does not allow programs to write files to any folder in "Program Files". When software write files to these folders they are redirected to a "Virtualstore" folder in the users own folder area which can cause confusion as you may end up with 2 copies of the file which are different. The same applies to the Data folder.
The Map and Data folders could be put in
  • the "User" folder - example c:\<user>\OziExplorer\Maps (<user> means your user name), this folder can only be seen by this user.
  • the "Public" folder - example c:\Public\OziExplorer\Maps , this folder can be seen by all users.
  • anywhere else you like - example c:\OziExplorer\Maps , this folder can be seen by all users. Note - if you are using a managed PC in a corporation or government area you may not have permission to write to any folders other than those in your user area.
If OziExplorer or OziExplorer3D does not run at all in Vista (Data Execution Protection - DEP Issue)
It seems that when Windows Vista - Data Execution Protection (DEP) is turned on for all programs it is causing OziExplorer (or OziExplorer3D) to crash on start-up. This shouldn't be a problem for 32 bit installs unless DEP is turned on specifically but 64 bit installs have it on automatically.
Follow the instructions below to fix this issue.
  • Open the Windows Control Panel
  • Select "System and Maintenance", then "System".
  • On the left side, there are a list of tasks, select "Advanced system settings".
  • On the Advanced Tab on the dialog (you'll probably have a security warning here), click on "Settings" button in the Performance section.
  • On the "Data Execution Protection" tab, your computer has "Turn on DEP for all programs except ones I list". You can either:
    1. Switch that setting to " ... essential programs and services ... ". This has the advantage of fixing problems you may be having with some other applications.
    2. Or you can add OziExplorer (and OziExplorer3D if also installed) to the exclusion list (browse to the directory where you installed, then select the executable).
  • Close the dialog, you may be asked to reboot your PC.
Vista issues for OziExplorer versions 3.95.4n or older
Issue
If you install OziExplorer into a subfolder belonging to the "Program Files" folder then it will not accept the registration unlock codes.
Workarounds
Install OziExplorer to the folder C:\OziExplorer
or
Run OziExplorer as Administrator. To do this right click on the shortcut and select the "Run as administrator" option from the menu.
Issue
Windows Vista regards the "Program Files" folder tree as a protected area and will not let programs write files into these folders. Therefore if you install OziExplorer into a subfolder belonging to the "Program Files" folder then it will write all new files into the "VirtualStore" folder which is part of the current user folder tree.
Workarounds
or
Run OziExplorer as Administrator. To do this right click on the shortcut and select the "Run as administrator" option from the menu. OziExplorer needs to be run as Administrator every time so it is better to add it to the properties of the OziExplorer shortcut. Open the properties of the shortcut by right clicking on the shortcut and selecting Properties from the menu. Select the Compatibility tab and tick the "Run this program as administrator" checkbox, if you cannot tick the checkbox you must press the Button "Show settings for all users" (below) and tick the checkbox on that screen.
Issue
Runtime Error 216 at 000032E0 when closing OziExplorer.
Workaround
This is a non critical error and can be ignored, just click OK to continue. The error occurs in OziExplorer within the compiler library code which was not written by us, this makes it more difficult to find the cause but we are attempting to fix the issue.
__________________
www.aawen4x4.com.au
Talk to us about your next trip!
Jules @ Aawen4x4 is offline
Old 19-07-2007   #6 (permalink)
4.2GUst
Senior Member
4.2GUst's Avatar
Default
im still having ttouble!!
i may have to buy a newer version!
__________________
4.2GUst is offline
Old 19-07-2007   #7 (permalink)
Jules @ Aawen4x4
Junior Member
Default
If you download the latest version and install over the top it will transfer your licence from any previous version of OziExplorer 3.9x to the new version.
Then the above information will make sure that everything works well.
Jules @ Aawen 4x4
__________________
www.aawen4x4.com.au
Old 19-07-2007   #8 (permalink)
4.2GUst
Senior Member
4.2GUst's Avatar
Default
yes but i cant even get it to run my old version i got a trial version that you could aivate with a reg key and it worked but my old one didnt and the new one wouldnt take my reg key
thanks jules
mike
__________________
4.2GUst is offline
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin® Version 3.8.2
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.0.0 (Unregistered)
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129
